Create Email Message Error
Thread begun 1/08/2013 1:25 pm by theorytl401135 | Last modified 4/22/2015 1:11 pm by Ray Borduin | 3097 views | 9 replies |
theorytl401135
I updated Data Bridge to the 1.1.2 and now when I try to Create an Email message from a file I get two different errors.
Either DW will crash altogether or if I'm lucky to get a dialog box opened to select the file that I want and I can select the file but then the dialog box opens up again and will not close after selecting the file. It just loops over and over.
How can I fix this?
have you tried Deleting the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
theorytl401135
Yes I have tried that multiple times and I also tried reinstalling the extension.
michaelf0199272
error message trying activate DataBridge\universal email (Data Bridge 1.2.2)
Uninstall and reinstall Data Bridge. It looks like you may have installed an older version of a WebAssist extension after Data Bridge, causing the error you have attached. A fresh install should clear it up. Clearing the filecache.dat file after installation with Dreamweaver closed wouldn't hurt.
michaelf0199272
I followed your suggestions --- it did not seem to work. When the extension was re-installed, the same error came up.
That error implies that you have uninstalled a webassist extension and then tried to open up Universal Email without a page open. I think if you have an open page when opening the interface you shouldn't get this error.
It looks like you have been struggling with this for a few days. If you post a U.S. phone number or Skype contact information if you are international, then I'll call you and do screen sharing so I can debug your problems and make sure you get up and running.
michaelf0199272
All these are happening in the process of installing/activating the new DataBridge vs 1.22
I'll help you debug this in a screen sharing session.
