Transferring from one live site to another.
Thread begun 1/07/2013 8:54 pm by akstudio | Last modified 1/08/2013 10:09 am by akstudio | 2140 views | 5 replies |
akstudio
I need a bit of direction.
I developed a site for a client, within my own domain, behind a password protected folder. I used powerCMS (design extender extension)
We have been hammering out edits, updates, etc. This all has worked flawlessly. Now, the client wants to go live.
This means I need to transfer all the assets to their server. Which I did, including an export of the DB
on the NEW server. I cannot get the site working at all. I understand there will be a few places to update paths, etc. I CAN connect to the DB fine, however, when hitting a page I just keep getting an "Internal Server Error - The server encountered an internal error or misconfiguration and was unable to complete your request. "
I feel like I need to allow powerCMS to "reinstall" somehow... but at the same time, I think the "reinstall" will force me to start over from scratch.
Where do I even start?
If I remove the line: <?php require_once("WA_CMS/WA_CMS.php"); ?> the site loads, without the DB content, of course.... adding that line just generates the internal server error.
that is a general error that will be retuned if error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
akstudio
ok that helped a ton, thanks.
I now have it down to 2 errors:
Warning: Unknown: open(/var/php_sessions/sess_97bf0b26b7b1b43665a7cdef57f7a743, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/php_sessions) in Unknown on line 0
I still need to go back and update a few paths, it may fix error 2
that is a problem with the server.
it means that the session.save_path setting in the php.ini file is not correct.
you will need to contact the host to have them correct the problem.
akstudio
This is the answer to the session issue:
To run PHP sessions, include the following code at the top of any PHP script that uses sessions:
session_save_path("your home directory path"/cgi-bin/tmp);
session_start();
To find "your home directory path":
Log into the PHP Scripting page for actual path to your home directory.
Replace "your home directory path" with the path shown.
Set session_save_path to a directory within your cgi-bin: either /cgi-bin/tmp as in the example above or another directory as long as the absolute path is correct.
I should just be able to add the /cgi-bin/tmp path into the php.ini, right?
akstudio
OK i got that issue ironed out - all good. Thanks for the help.
