errors with old code
Thread begun 1/04/2013 5:56 pm by paulshoe379536 | Last modified 5/17/2013 3:25 am by CJ | 4469 views | 9 replies |
paulshoe379536
I have upgraded to Data Bridge and CS6.
When opening previously created pages, I seem to be getting errors in server behaviors like:
"It appears that one of your server-side values is improperly coded.
Please check the interface for inconsistencies."
and
"TypeError: theVal has no properties" (then the widget dialog window is blank)
2) Server behaviors are not recognized at all (insert, update) on some pages.
Is there a document that explains procedures necessary when upgrading from Data Assist to Data Bridge?
Can you send a copy of a page where you are having this problem please.
paulshoe379536
files attached
I have included three files:
activity_groups_Update.php -- original file from winXP and DW 5 and DataAssist
server behavior for update not recognized and error showing on SecurityAssist behavior
activity_groups_Insert_1.php -- original file from DataAssist
Insert behavior not recognized and error showing on SecurityAssist behavior
activity_groups_Insert_2.php -- I updated the original SecurityAssist behavior this updated the "require_once" to a new path/file and corrected the error.
I deleted the original code for the record insert and added it again using the new DataBridge widget. "Insert record" is still not included in server behaviors.
paulshoe379536
Jason,
It seems like I've corrected most of my problems. Changing the syntax of the "$WA_redirectURL" expression seemed to be help. I will close the support ticket.
Thanks for all your help.
CJ
same error: uiInitialize error TypeError: theVal has no properties
Hi Jason,
On my page is still an prior version of the Update record.
When I doubleclick on this serverbehaviour I'm getting the same error on an update page:
"uiInitialize error TypeError: theVal has no properties"
Using DW6 and DataBridge.(Already cleared the cache)
Do you know what to do?
please send a copy of the page and a SQL dump of the table structure that it is using so i can recreate the problem to investigate the cause.
CJ
looks like you hand edited the code to add the forth column in rather than use the Update record interface.
change lines 79 - 81:
$WA_fieldValuesStr = "".((isset($_POST["Artikel1"]))?$_POST["Artikel1"]:"")  ."" . "|" . "".((isset($_POST["Artikel2"]))?$_POST["Artikel2"]:"")  ."" . "|" . "".((isset($_POST["Artikel3"]))?$_POST["Artikel3"]:"")  ."|" . "".((isset($_POST["Artikel4"]))?$_POST["Artikel4"]:"")  ."";
  $WA_columnTypesStr = "none,none,NULL|none,none,NULL|none,none,NULL";
  $WA_comparisonStr = "=|=|=";
$WA_fieldValuesStr = "".((isset($_POST["Artikel1"]))?$_POST["Artikel1"]:"")  ."" . "|" . "".((isset($_POST["Artikel2"]))?$_POST["Artikel2"]:"")  ."" . "|" . "".((isset($_POST["Artikel3"]))?$_POST["Artikel3"]:"")  ."" . "|" . "".((isset($_POST["Artikel4"]))?$_POST["Artikel4"]:"")  ."";
  $WA_columnTypesStr = "none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL";
  $WA_comparisonStr = "=|=|=|=";
CJ
Hi Jason,
Yes it would be possible that I handcoded this some time ago.
The code you gave me worked. I can now update the "Update Record" to the latest version.
Thanks a lot.
