Trouble with getting a session value to work
Thread begun 1/02/2013 4:53 pm by mrs | Last modified 1/03/2013 12:02 pm by Jason Byrnes | 2070 views | 3 replies |
mrs
I have tried on numerous occasions to use a session variable via Server Behaviours --> WebAssist --> Cookies --> Set Session Value and applying these settings of Trigger: Recordset is not empty, Session Name: threadID, Value: fld_fID which is the unique ID I am trying to use.
When I place the session variable 'threadID' on my detail page in design view to test it's working, nothing is displayed which implies it is empty. Why is this?
I watched some of your tutorials on building particular parts of websites, and I seem to have applied similar processes when setting a session variable, but I am not getting a value! I can get the value to display if I place the binding from the recordset, but this isn't going to help in what I need. I am trying to take the unique ID of an article on the detail page and allow users to post a response to it via an insert page. It's the insert page page that needs the unique ID of the original article.
I can do this by using a URL variable, but this isn't particularly brilliant because all a user needs to do is change the ID in the address bar and they could be replying to any other record... so I was hoping to use a session variable.
Basically, I am trying to create a very simple forum!
mrs
Just to clarify, am I using a session variable in the right way here? Should I be doing this in some other way?
mrs
OK, OK, I have just figured it out... I am getting good at this php malarkey... NOT!
Whenever I inserted the session variable, it was inserting at the top of the code just below the require_once file info, but crucially above the recordset that I was trying to collect the info from... so obviously, as the session had been read before the recordset, it was empty.
So, in order to ensure that I am not carrying the incorrect session ID from one record to another once a user has inserted a reply, on the resultant detail page, I have cleared the session variable. Is this the correct procedure?
Am I tackling this in the correct manner? Is a session variable the correct method, and is clearing its value a requirement/good practice?
Yes, using a session is the best way to accomplish this.
clearing the session after the insert is also a good practice.
