onLoad works on Chrome but not IE or Firefox
Thread begun 12/29/2012 9:46 am by Jared Lui | Last modified 1/02/2013 9:55 am by Jared Lui | 6196 views | 6 replies |
Jared Lui
I'm using a Spry Accordion and have it working as intended in Chrome however both Firefox and more importantly IE only partially work. Rather than move to JQuery straight off, I'd like to see if I can fix this with the help of any experts here. Thanks in advance.
If you view this page in Chrome:
figure_lines_Detail.php?Line_Id=30
You'll notice that the accordion on the right side goes 4, 3, 2, 1 with the last panel (1) open.
When viewed in IE and FF the accordion goes 4, 3, 2, 1 however the first panel (4) is open.
I used this code to make it work in Chrome:
<body onLoad="MM_callJS('Accordion1.openLastPanel(); return false;')">
I can provide the page code and all helper files as needed. I am hoping someone will know of a IE/FF work around to save me from recreating this accordion. NOTE: This accordion has a repeat section inside a repeated section and was difficult to create so that's why I'd like to see if I can fix this Chrome vs IE/FF issue if I can.
Thanks in advance!
see the spry documentation here:
help.html?content=WSDBFCA944-4E99-421a-9328-8533440AA7F3.html
In the navigation, the link for "Set the default open panel" says:
  You can set a certain panel to be open when the page containing the Accordion widgets loads in a browser.
Set the defaultPanel option in the constructor as follows:
var acc8 = new Spry.Widget.Accordion("Accordion8", { defaultPanel: 2 });
</script>
Note: The accordion panels use a zero-based counting system, so setting the value to 2 opens the third panel.
on your page, the code to initialize the accordion is:
var Accordion1 = new Spry.Widget.Accordion("Accordion1");
</script>
add ", { defaultPanel: 3 }" to that to force the forth tab to be the default open tab:
var Accordion1 = new Spry.Widget.Accordion("Accordion1", { defaultPanel: 3 });
</script>
Jared Lui
Hey Jason, thanks for the response.
I already have the link you refer to bookmarked and know about the default panel setting; however this does not apply in my case as those panels are dynamic and the number of them is not constant hence my use of "Accordion1.openLastPanel" which works perfectly in Chrome.
I'm not tech savvy enough to know why it does not work in IE/FF or how to code a similar fix for them or who or where I should ask. Any leads are appreciated.
The Adobe Spry forums would be the best place to ask for help on this issue:
spry
Jared Lui
Yeah, I have a request for help there too but since they don't really support Spry much anymore I usually have better luck here. We'll see what happens. Thanks for the response.
We must away! We must away!
We ride before the break of day!
Heres a thought, any record set you create will have a variable to return the number of rows.
you can use that variable - 1 to set the default panel. for example:
var Accordion1 = new Spry.Widget.Accordion("Accordion1", { defaultPanel: <?php echo($totalRows_recordsetName 1); ?> });
you have to subtract 1 because the panels are indexed starting at 0.
Jared Lui
Nice!
Now why didn't I think of that? Don't answer...
Thanks Jason, again.
