Insert page not inserting
After recent update, new set created, the insert isn't inserting. It returns the insert page blank and nothing has reached the db. Any ideas? Thanks.
entered a record directly into db thru myadmin... tried to update record from databridge and the updates wouldn't "stick"... I'll redo and see if something didn't work during installation...
Pulled the pages, redid and same result. No insert, no update function working. It's a simple 3 field set, one of which is the html editor. I'll run another test without the editor to see if that makes any difference.
Uninstalled db bridge, reinstalled. Re-ran tests, same results.
The pages are behind protected directory so can't post.
Zipped files for results, update and insert.
On a mac. Thanks.
one more note... trash can doesn't work either.
I uninstalled and reinstalled 1.0.9 for now. After holidays, perhaps we can take a look at what's going on with the 1.1.1.
Happy holidays.
I've opened a support ticket for you. When you are back from the holidays, please update the ticket with a good time and number to reach you and we can debug this with you and get it resolved.
Over and beyond support. WA is terrific. On a holiday weekend, Ray solved this for me. Amazing support. Thanks so much again.
