Pre-Set Layouts without Lines
Thread begun 8/09/2009 4:29 pm by annonreg366474 | Last modified 8/10/2009 10:29 am by Justin Nemeth | 3614 views | 2 replies |
annonreg366474
I've successfully set up my EW2 webpage using CSS Sculptor. My last issue is that I do not want a line separating the various boxes (e.g. between content and footer, or between a column and the main content. Is it possible to hide those lines?
patgeary300487
All you have to delete is delete the border style which is part of the style rule for that section.
Pat Geary
MS MVP Expression Web
www.expression-web-tutorials.com/
Justin Nemeth
Pat is correct. On the Design tab in the wizard, select your component (i.e. your leftColumn) then unset the properties for the border.
