mysql date field removing record
Thread begun 12/20/2012 7:42 am by john70964 | Last modified 12/20/2012 12:07 pm by Jason Byrnes | 3422 views | 6 replies |
john70964
I am using mysql db
I want to be able to create a date field
which will create a date of today plus 90 days.
This should cause a record to disappear from a results list after 90 days.
Can anyone advise the best way of achieving this please?
Many thanks
John
in the database, use a timestamp column type for the date, and set the default value to:
CURRENT_TIMESTAMP
this will store the current date when a record is created.
then in the recordset you filter out records that are over 90 days old in the WHERE clause using:
WHERE dateColumn + INTERVAL 90 DAY >= now()
john70964
Thanks Jason
When I did that and tried to save it brought an error message.
I attach an image which I hope demonstrates the problem.
Regards
John
uncheck the allow null option
john70964
Sorry to say that did not change the error message still appears, I also tried unticking the box for On Update Current_timestamp.
John
john70964
I believe there's no length parameter to timestamp.
I now have 0 zero
I also had to untick the box On Update Current_Timestamp
That seems to work OK
glad to hear it is working.
