Multiple row update question
Thread began 12/17/2012 9:10 am by CraigR | Last modified 12/19/2012 11:00 am by Jason Byrnes | 1193 views | 5 replies |
CraigRBeta Tester
I have a member registration form which allows multiple email addresses to be associated with an account.
I have a repeat selection loop on the data insert form with 3 iterations so that up to 3 addresses can be added to a joined table using the multiple record insert behavior.
This works fine, but on the update form, i get only the the number of rows in the recordset returned, so, for example, if one address was entered for a member, only one row is returned.
i would also like to display 3 rows on the update table, so there is an opportunity to add additional email addresses.
Make sense ?
on the update page, set the repeat selections to use 3 instead of the recordset.
CraigRBeta Tester
hi jason,
i tried that, but i get the first row in my recordset returned 3 times.
if this isn;t what is expected, i'll try again
use 3 for repeat selection, but then add a repeat region around it to loop through the recordset.
CraigRBeta Tester
Thanks Jason.
I did try the nested loop, and appearance wise, got it looking ok, but then realised that, because my contact details are in a linked table, i need to use insert server behavior on any new data.
Went back to a repeat region and added an extra field for any additional data and applied insert behavior to this
Ok, glad to hear you have it working.
