DataAssist Search from checkbox
Thread begun 12/16/2012 4:14 pm by eric284736 | Last modified 12/18/2012 10:26 am by Jason Byrnes | 2769 views | 5 replies |
eric284736
Hi Jason,
I have setup a search thru the search wizard where multiple checkboxes can be selected.
search-clothes.php
The checkboxes have the same name lettersize[] and correctly returns the records from one checkbox (example size 6(S) is checked and those items are shown on the results) if I select size 6(S) and size 8(M) only items from ONE of the selections are shown.
The results page must not be set correctly. Here is the comparison list in the code:
$WADbSearch1->addComparisonFromCheck("lettersize","lettersize","".((isset($_POST["lettersize"]))?$_POST["lettersize"]:"") ."","","AND","=","<>",1);
$WADbSearch1->addComparison("items.ItemCatID","".((isset($_POST["ItemCate"]))?$_POST["ItemCate"]:"") ."","AND","=",1);
Should this be set for Keyword?
thx
Eric
In the keyword criteria for the checkbox, make sure to set the OR separator to ", " (a comma followed by a space).
with a multiple checkbox, the selections are sent as an array, the array needs to be converted to a comma separated list.
add the following code at line 1 for this:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
        if(
is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
eric284736
Thanks Jason. I have the code inserted at line 1.
Not sure I understand where to change the separator. I have attached the 2 screen shots of the search panel.
thx
Eric
in the second screen shot, you have the filter type set to check, change it to keyword and make the OR seperator is set to ", "
eric284736
Thanks! I made that change, but it still only pulls 1 size selection.
search-clothes.php
if you select 6(S) and 8(M) it only shows the 6(S)
thx
Eric
