New Tags Sculptor
please add new Tags like CLEAR and P.
Why is such an important tag like CLEAR not in the extension?
Please add.
Denis
Please add.
Denis
Why use clear in an page layout. Whenever I use clear (if i ever use it at all) it 's most of the time used for images which I consider as an inline.
Why use <p> (paragraph) for page layouts, it's clearly just a part of the text layout within a (text-)block.
I think that using these tags as page layout elements in CSS sculptor will ruïn the layout, or worse, makes it extreemly ambiguous.
Grtz,
Clear is a CSS property that can be applied to a html tag. I would actually recommend using the "overflow: hidden" property instead. Apply that to the div wrapper that contains your floated elements. This will give you the desired clear effect, but works more consistently.
I would be nice if the P tag is also in the list on top of the CSS where all is set to ZERO.
Why P? Why is H1 H2 H3 H4 there?
The Clear, is ok, if I use overflow HIDDEN. I thought Clear is for float, so I learned it.
But if overflow HIDDEN will do the same, ok.
Denis
You can just add the p tag to that top reset CSS if that works for you. The thing to keep in mind with resetting the p tag, is you should define your own margins. By default a p tag has margins so that you can use multiple paragraphs and stiff have space between them. We don't reset the p tag since for most people they want to retain the spacing.
