Order Number
Hi Jason,
My order number is not increasing and I m using this code...
<?php echo ((isset($_SESSION["Hosting_Services_OrderID"]))?$_SESSION["Hosting_Services_OrderID"]:""); ?>
VAN YOU PLEASE HELP...
Hi Jason,
are you closing the browser between transaction tests?
make sure you completely close the web browser between tests.
also, try adding the following code to the end of the checkout success page:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
@setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
@session_destroy();
@session_regenerate_id();
I try that and is not working at all I dont event see any order number at all...
