e-cart activation error
Thread begun 8/09/2009 8:54 am by datacate | Last modified 1/11/2010 10:43 am by Eric Mittman | 4137 views | 5 replies |
datacate
I have attempted to activate my e-cart software and am getting the following error each time I try:
Unexpected error 2, Activation cannot be completed
I have reset my activation in the control panel but am still getting the same error.
Would appreciate some help
I have opened a ticket for you on this issue. Please login to WebAssist.com and visit the support history page to update your ticket. Please include the information requested by the ticket.
tonypollard335523
activate your eCart4 software
21.09.09
Dear Sirs
I am trying to simply activate your eCart4 software, but when I put in the correct serial number your program gives me the message that it CANNOT find my internet connection for activation.
I have tried this on 2 different internet providers and switched off my anti-virus and firewall protection but your software still states that it CANNOT find the internet connection.
Could you please inform me how I can get your software to work.
Regards
Tony Pollard
Jimmy Wu
I have opened a backend support ticket for you. You can check this by logging into your account at www.webassist.com and checking your support history. Please post back with the information requested so we can help you with your activation.
tonypollard335523
e-Cart activation error
10.01.10
Hi
Before Christmas I had problems activating and loading your software due to it not finding my internet connection.
You emailed a license.dat file to place in the Dreamweaver 9\Configuration folder
Upon doing this I was able to load your software as a managed extension to my Dreamweaver CS3 software and thus bypass your software’s constant requested for activation.
But when I now try to use the eCart4 software (eCart object Add) I am again greeted with the Web Assist online activation window that again states ‘NO INTERNET CONNECTION DETECTED’ even when the internet is provided through a proxy server.
Is it possible to inform me of how I can use your software, so that I do not have to contact you every time I try to use one of its commands?
Regards
Tony Pollard
tonypollard@lineone.net
ipconfig.txt file details:
Windows IP Configuration
Host Name . . . . . . . . . . . . : agoco-ef64be012
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controller
Physical Address. . . . . . . . . : 00-11-11-67-91-F5
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 132.1.11.150
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Originally Said By: tonypollard335523
  21.09.09
Dear Sirs
Regards
Tony Pollard
I have opened a ticket for you on this. To update the ticket please login to WebAssist.com and visit your support history.
