Datepicker - European format
Thread begun 12/05/2012 11:45 am by thehalpeen319342 | Last modified 1/04/2013 11:20 am by Massimo | 5438 views | 13 replies |
thehalpeen319342
Dear Jason,
I have set the format of my CSS Form Builder datepicker to dd/mm/yyyy. However, when it the date is submitted and then displayed in my browser it displays as 0000-00-00. It also displays like that in the mysql table. Can WebAssist help me to have the record displayed as dd/mm/yyyy ?
the date format entered in the database must be yyyy-mm-dd
you can convert the date format when the form is submitted by using code similar to this at line (this example assumes the date element is named "date"):
if(isset($_POST['date'])) {
$_POST['date'] = date("Y-m-d"strtotime($_POST['date'] ));
on your page, where you display the date, you can convert it to your format using:
<?php echo(date("d/m/Y"strtotime($row_recordsetName("dateColumn"))); ?>
thehalpeen319342
Jason, My date element is DOB (Date of Birth). I've tried to replace the DOB section of the insert, but I keep getting syntax errors. What exactly do i need to replace. Below is my insert code:
// WA DataAssist Insert
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) // Trigger
$WA_connection = $CommSimpleRegister;
$WA_table = "familymembers";
$WA_sessionName = "family_member_ID";
$WA_redirectURL = "welcomepage.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "fKey_Household_id|memberEmail|UserFirstName|UserLastName|UserPhone|memberDOB|memberLineage|photo";
$WA_fieldValuesStr = "".$_SESSION['SecurityAssist_familyID'] ."" . $WA_AB_Split . "".((isset($_POST["Email_Address"]))?$_POST["Email_Address"]:"") ."" . $WA_AB_Split . "".((isset($_POST["First_Name"]))?$_POST["First_Name"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Last_Name"]))?$_POST["Last_Name"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Phone_Number"]))?$_POST["Phone_Number"]:"") ."" . $WA_AB_Split . "".((isset($_POST["DOB"]))?$_POST["DOB"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Lineage"]))?$_POST["Lineage"]:"") ."" . $WA_AB_Split . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,NULL|',none,''|',none,''";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_connectionDB = $database_CommSimpleRegister;
@session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
if ($WA_redirectURL != "") {
$WA_redirectURL = str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
use the following code at line 1:
if(isset($_POST['DOB'])) {
$_POST['DOB'] = date("Y-m-d"strtotime($_POST['DOB'] ));
thehalpeen319342
Ok Jason, I forgot to ask you where exactly to put <?php echo(date("d/m/Y", strtotime($row_recordsetName("dateColumn"))); ?> - instead of dateColumn I use memberDOB.
So I've adjusted the code and replaced the following:
value="<?php echo $row_rsMembers_Update['memberDOB']; ?>"
with
value= "<?php echo(date("d/m/Y", strtotime($row_rsMembers_Update("memberDOB"))); ?>"
But I get syntax errors.
Below is my current code (before adjusting)
<span>
<input id="DOB" name="DOB" type="text" value="<?php echo $row_rsMembers_Update['memberDOB']; ?>" class="formTextfield_Medium" tabindex="6" onblur="hideServerError('DOB_ServerError');"/>
<span class="textfieldInvalidFormatMsg">Invalid format.</span><span class="textfieldRequiredMsg">Please enter or select a date</span> </span> </span>
sorry, mixing my square brackets and parenthesis. the correct code would be:
value= "<?php echo(date("d/m/Y"strtotime($row_rsMembers_Update["memberDOB"])); ?>"
thehalpeen319342
Jason, Thanks for that, but I'm still getting a syntax error - see attached screenshot.
I've done the following change:
Prior to change:
<span>
After change - adjustment to code:
<span>
<input id="DOB" name="DOB" type="text" value="<?php echo(date("d/m/Y", strtotime($row_rsMembers_Update["memberDOB"])); ?>" class="formTextfield_Medium" tabindex="6" onblur="hideServerError('DOB_ServerError');"/>
Where have I gone wrong?
try changing the code to:
value="<?php echo(date("d/m/Y", strtotime($row_rsMembers_Update['memberDOB'])); ?>"
do you have the same error running the page in your web browser? sometimes Dreamweaver syntax highlighting will show an error when there really is not one.
thehalpeen319342
Jason,
I'm still getting the syntax error, and when I check the page in the browser, I am presented with a 'blank' page.
Attached is the php page with value="<?php echo $row_rsMembers_Update['memberDOB']; ?>"
I think i see the problem, a missing ) at the end.
try this code:
value="<?php echo(date("d/m/Y", strtotime($row_rsMembers_Update['memberDOB']))); ?>"
