Insert/update from same page
Thread begun 12/05/2012 5:16 am by aladdin229745 | Last modified 12/05/2012 2:39 pm by aladdin229745 | 3427 views | 6 replies |
aladdin229745
On one particular page I would like user to enter data then if they come back they can see all the full and empty fields and update if they want to. DataAssist creates 2 pages to be able to do this. Insert.php and update.php. I would like to be able to use just one of them so the user can insert and update from the same page. I think this can be done with a little code editing but I cannot work it out. If someone achieved this in the past please can you share your ideas.
Many thanks
Aladdin
if you take a look at the update page, there is a recordset that is filtered using a URL variable, this recordset is used to populate the form with the values to be updated.
to be able to insert and update on the same page, you will need to have 2 buttons for the form. In the insert behavior, set the trigger to Button insert pressed. in the update behavior, set the trigger to button Update pressed.
be aware, though, that using the form for double duty like can cause confusion. The user may go to update a record and click the Insert button instead causing the updates to be lost for the original record, and stored as a new record instead.
From a user perspective, it may not be a great idea to make a page that can do both, just because it can be done, does not mean it should.
aladdin229745
Thanks Jason,
Yes, I have considered several ways to do this and could not find a solution. Ideally we need to have just one button. So when the user comes to the page first time, all the fields are empty. Then they may enter some data and comeback to it another time to add more data. I am stuggling to work out the first part - when the form is visited first time. I need to be able to register the data in the tables. After the first time the update page function should work perfect.
I have manage to sort this out in Powermessanger when I was building the extra pages for the users by making a copy of a page and jugling the code round (maybe 24 hours later). But this one, I am really stuck.
If you can come up with a solution (one button for all) please let me know. Thanks
can really be done with only one button without considerable custom coding.
aladdin229745
I buy you a beer if you let me know the secret fomula. Better than pulling my hair :-)
there really isnt a secret formula, just a lot of if statements to check that the form is empty on initial load, if it is, perform the insert, if the form is populated by the recordset, do the update.
aladdin229745
I have tried to use 'if, else' statements yesterday. I think I was close but I couldn't get it working. I will study and learn a little more about it tonight.
