Date Time Validation
Thread begun 11/29/2012 2:23 am by Cologne | Last modified 11/29/2012 12:02 pm by Cologne | 3658 views | 7 replies |
Cologne
Hello,
I need some help with the Date/Time validation.
I want to check the age, via, 3 select boxes.
I use this validation yyyy-mm-dd
I think the problem are the select boxes. Cause if I use a simple input field, it works well.
To fix I tried to create the month and day value with date "n & j" but I think this does not work with the yyyy-mm-dd
Cheers,
Denis
Cologne
I think I got the error.
it must be.
$WAFV_Errors .= WAValidateDT(((isset($_POST["year"]))?$_POST["year"]:"").'-'.((isset($_POST["month"]))?$_POST["month"]:"").'-'.((isset($_POST["day"]))?$_POST["day"]:"") . "",true,"\b\d{4}-(1[0-2]|0[1-9])-([12]\d|3[0-1]|0[1-9])\b","","".(date("Y-m-d", mktime(0, 0, 0,  date("m"), date("d"), date("Y") - 18)))  ."",false,".*","","",true,8);
maybe someone can check this :-)))
yes, the problem is the format of the Max date setting
in the original you have:
<?php echo (date("Y-m-d", mktime(0, 0, 0, date("d"), date("m"), date("Y") - 18))); ?>
the mkdate function takes the date pieces in this order:
hours, minutes, seconds, month, day, year
you are not passing them in the correct order
Cologne
Hey Jason,
do you know why 12 is coming before 1?
<select name="month" id="month">
<option value="0" <?php if (!(strcmp(0, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Monat</option>
for($m=1; $m<=12; $m++){ ?>
<option value="<?php echo date("m", mktime(0, 0, 0, $m, 0, 0)); ?>" <?php if (!(strcmp(date("m", mktime(0, 0, 0, $m, 0, 0)), (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>><?php echo date("m", mktime(0, 0, 0, $m, 0, 0)); ?></option>
<?php } ?></select>
looks like register_step_1.php
is there a way to fix the order?
Cheers
Denis
that page does not load for me, please post a valid link where I can see the problem
Cologne
register_step_1.php?register=false
sorry!
in this code:
you pass 0 for the day, this tells the make time function to use the last day of the previous month in other words, december 31. the day and the year should pass a valid value
<?php echo date("m", mktime(0, 0, 0, $m, 1, 2012)); ?>
Cologne
I did it without 2012 and works.
Thanks so much!
Denis
