ActionSports Template
Thread begun 8/08/2009 2:34 pm by tirzahm338096 | Last modified 8/10/2009 10:44 am by Anna Robinson | 2886 views | 3 replies |
tirzahm338096
I'm trying to add my newly purchased ActionSport website as a new site-assist pro template and it tells me that it isn't a valid SiteAssist Professional layout. I did read in a separate help thread that it needs to be directed to the correct zip file; however there is just the one initial zip (ActionSports100.zip) and none beyond.
Dani Chankhour
ActionSports100.zip is an html template. To use it, you need to unzip it, and then copy the files in ActionSports_website folder to your site.
tirzahm338096
so i can't at all use it as a additional siteassist pro template?
Anna Robinson
Can Use DWT
The ActionSports website template is not directly compatible with SiteAssist Pro - there is not a zip to import. For everyone's reference, in SuCasa, when you are looking at the detail view of a template, there is an area that says COMPATIBLE PRODUCTS. This area will list extensions that the package is compatible with. If an extension is not listed, it does not have a zip you can import.
However, SiteAssist Pro can work with DWTs. The package should have a DWT in the Templates folder and you could use the SiteAssist Pro Layout Manager to set up a site with that template. As Dani mentioned, set up a site in Dreamweaver, including the ActionSports files. Go the SiteAssist Pro Layout Manager. Click on the New button and you can choose a DWT within that site to build out pages with.
You won't automatically get the content of every page we've set up in this package; you'll be building new pages with the template. But with some copy/paste once you've finished the wizards, you could come up with something similar. Or of course, you can use the whole ActionSports pages stand-alone and not utilize SiteAssist Pro.
