Validated Entries In PHP Loop
Thread begun 11/28/2012 12:12 pm by Cologne | Last modified 11/29/2012 6:55 am by Jason Byrnes | 7020 views | 6 replies |
Cologne
Hello,
I create my year select field with a for loop.
How can I make it selected with the Validation Entries Form Element.
<select name="year" id="year">
<option value="0">Year</option>
for($y=date('Y'); $y>=date('Y')-100; $y--){ ?>
<option value="<?php echo $y; ?>"><?php echo $y; ?></option>
<?php } ?>
</select>
Cheers,
Denis
you will need to hand code it.
change:
        <?php } ?>
        <option value="<?php echo $y; ?>" <?php if (!(strcmp($y, (ValidatedField("pagename","year"))))) {echo "selected=\"selected\"";} ?>><?php echo $y; ?></option>
        <?php } ?>
Cologne
Hi Jason,
perfect, works fine!
Thanks a lot!
Denis
Cologne
Hi Jason,
is there a way I can use numbers like 01,02,03 for month, so they fit in the database style.
I validate them with the date/time server behavior yyyy-mm-dd
But this does not work with.
<select name="month" id="month">
<option value="0" <?php if (!(strcmp(0, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Monat</option>
<option value="1" <?php if (!(strcmp(1, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Januar</option>
<option value="2" <?php if (!(strcmp(2, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Februar</option>
<option value="3" <?php if (!(strcmp(3, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>März</option>
<option value="4" <?php if (!(strcmp(4, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>April</option>
<option value="5" <?php if (!(strcmp(5, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Mai</option>
<option value="6" <?php if (!(strcmp(6, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Juni</option>
<option value="7" <?php if (!(strcmp(7, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Juli</option>
<option value="8" <?php if (!(strcmp(8, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>August</option>
<option value="9" <?php if (!(strcmp(9, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Sptember</option>
<option value="10" <?php if (!(strcmp(10, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Oktober</option>
<option value="11" <?php if (!(strcmp(11, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>November</option>
<option value="12" <?php if (!(strcmp(12, (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Dezember</option>
</select>
if I do it with simple nubers my age check doesnt work cause auf the choosen yyyy-mm-dd
If I use 01,02,03 the Validation Entries doesnt work anymore :-(
make sure the comparison value is in quotes, for example:
<option value="00" <?php if (!(strcmp("00", (ValidatedField("registerstep1_250","month"))))) {echo "selected=\"selected\"";} ?>>Monat</option>
Cologne
Hmm, this does not work.
here is my validation code:
$WAFV_Errors .= WAValidateDT(((isset($_POST["year"]))?$_POST["year"]:"").'-'.((isset($_POST["month"]))?$_POST["month"]:"").'-'.((isset($_POST["day"]))?$_POST["day"]:"") . "",true,"\b\d{4}-(1[0-2]|0[1-9])-([12]\d|3[0-1]|0[1-9])\b","","".(date("Y-m-d", mktime(0, 0, 0,  date("d"), date("m"), date("Y") - 18)))  ."",false,".*","","",true,8);
And this is the Server Variable
The Value for Day and Month I did like you said.
<option value="0" <?php if (!(strcmp(0, (ValidatedField("registerstep1_250","day"))))) {echo "selected=\"selected\"";} ?>>Tag</option>
<option value="01" <?php if (!(strcmp("01", (ValidatedField("registerstep1_250","day"))))) {echo "selected=\"selected\"";} ?>>1</option>
<option value="02" <?php if (!(strcmp("02", (ValidatedField("registerstep1_250","day"))))) {echo "selected=\"selected\"";} ?>>2</option>
<option value="03" <?php if (!(strcmp("03", (ValidatedField("registerstep1_250","day"))))) {echo "selected=\"selected\"";} ?>>3</option>
I think its the format, used in the Date/Time validation yyyy-mm-dd
something is wrong.
If I do it with a simple textfield it works, cause the user enters the right format yyyy-mm-dd
you started a new thread for this here:
showthread.php?p=141713&posted=1#post141713
