Update Record - bindings
Thread begun 11/28/2012 5:24 am by thehalpeen319342 | Last modified 11/30/2012 6:44 am by Jason Byrnes | 3722 views | 14 replies |
thehalpeen319342
Jason, am I going mad. This form I'm building has opened a can of worms. Just when I thought it was finished, more problems arise on testing - it's a marathon - I'm going daft.
Okay calm down!!!
Some background: Firstly I ran DataAssist Pages, just to see the code behind a CRUD system. As a result I have two questions.
1. How did you bind the Insert and Update page.
Update Page
The code used in email is <?php echo((isset($_GET["invalid"])?ValidatedField("usersupdate","UserEmail"):"".$row_WADAusers["UserEmail"]."")); ?>
Insert Page
The code used in userfirstname is <?php echo((isset($_GET["invalid"])?ValidatedField("usersinsert","UserFirstName"):"")); ?>
Where did this code come from - there is all sort of stuff in there - I've tried to bind using everything I can see on the bindings page - see my attached pdf - but nothing comes close to entering this robust code
It's driving me mad - almost!!!
the biding code for the insert page is generated by the Validated Entries bindings. This will only be available if you use Server Validation to validate the page.
If you add Server Validation to validate the form on the insert page, a new binding group will be added to the bindings panel named Validated Entries, it is used to retain information in the form when validation fails.
the binding code on the update page is a modified version of the validated entries code.
on the update page, the server validation behavior is set to send a URL variable named invalid.
On initial load, the values from the WADAusers recordset are used to populate the form fields. If the form is submitted, and fails validation it uses the validated entries binding.
this is not code that will be generated by the bindings panel, it has to created manually
thehalpeen319342
Okay Jason, I'm lost. I did the following:
I created a page called insert_test.php. I added a form with only one field 'first name'. I applied the WA Insert Record behaviour. I then created a WA Server Validation - a 'require' validation. This created a folder in the bindings panel called 'WA Validated Entries'. I dragged the only field in this folder over to the form field name 'first name' to bind it, and this is what appears in the field:
<?php echo(ValidatedField("inserttest_365","f_name")) ?>
It's a lot different than:
The isset part seems to be missing. What am I doing that's incorrect?
your not doing anything incorrectly.
the bindings panel does not generate the isset version of the code, if you want to use the isset version of the code:
1) set the failed redirect to pass the invalid url variable:
pagename.php?invalid=true
2) manually add the isset check
<?php echo((isset($_GET["invalid"])?ValidatedField("usersinsert","UserFirstName"):"" )); ?>
the isset check is a ternary expression, in other words a shorthand if stattement, in the form of:
question?if true:if false
in this case the question is:
the true part is:
and the false part is:
or a blank string.
thehalpeen319342
Jason, I think I'm getting out of my depth. So if I have say twenty fields, I have to manually add the 'isset' part at the beginning and a few commas, brackets at the end of each input field.
What is the difference between:
and
and
there are lots of diferances, page name, field name etc..
to convert:
would be:
<?php echo((isset($_GET["invalid"])?ValidatedField("inserttest_365","f_name"):"" )); ?>
thehalpeen319342
Jason,
Am I correct in saying, that if I use CSS Form Builder, I don't have to worry about any of this coding/isset stuff on an insert page, because the CSS Form Builder takes care of it?
So the only thing is to deal with is the Update page. Does Form Builder write the code for the update?
only the data assist wizard would create the code for you on the update page and insert page.
thehalpeen319342
Ok, thanks
thehalpeen319342
This post has been deleted.
