error message WA_Memento.htm
Thread began 11/27/2012 6:43 am by pat356751 | Last modified 11/27/2012 7:02 am by Jason Byrnes | 604 views | 1 replies |
pat356751
After installing DataBridge, DreamWeaver CS6 starting showing a warning message, "Unable to find the WA_Memento.thm in the Configuration/Floaters directory. The Floater will not be shown." Before installing the DataBridge Extension, I uninstalled several WA Extensions with the Adobe CS6 Extensions manager. Also, whenever a Dreamweaver CS6 file is saved, a " While executing onLoad in WAUE_afterSave.htm the following JavaScript error(s) occurred; In file "WAUE_afterSave: cmdRun is not defined" warning is displayed. Hope someone can help.
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
