Group Discounts
Thread begun 8/08/2009 11:44 am by kenp276561 | Last modified 8/10/2009 1:45 pm by kenp276561 | 2091 views | 2 replies |
kenp276561
Group Discounts
I need advise on how to set up a Discount in eCart based on a session variable that holds a percentage amount. The session variable is on the cart page. Any advise would be greatly appreciated.
This type of discount is fairly straight forward. If you are already setting the session variable to a percentage then in the discount rule you will specify 'if session variable exists' and enter the name for your variable. Then for the calculation portion you just base it off of the cart subtotal times your percentage, you can just enter the session variable like this:
$_SESSION['<your var name>']
We have more information on discounts, charges and coupons that can be found on the eCart support page under Solution Recipes and How Tos.
ecart/
kenp276561
Thanks for your advise. It worked perfectly. Other than your advise, I just had to add a decibel point to the the session variable.
