rounded corner layout question
Thread begun 8/08/2009 10:46 am by edrosenthal350859 | Last modified 8/24/2009 2:53 pm by Dani Chankhour | 3562 views | 3 replies |
edrosenthal350859
I am using the rounded corner layout with header and footer, and both footerTop and headerTop have squared areas that have a white background. Very little of it is displayed, maybe 3-4 pixels, but is a visible area that should be transparent, so that the image is completely rounded without any of that squared off effect. The particular layout and choice of colors ( i think it was poppy or yosemite, can't remember), those should be the colors there instead of white. I tried to find the image going thru all the css background URL rules for these images but cannot find the one to change canvas color or attempt to change its opacity. Perhaps i am looking in the wrong direction. perhaps i should try to make contentwrapper transparent?
Justin Nemeth
Can you please post a link so I can look at the page?
What browsers is this problem occurring in?
Other than selecting the built in rounded corner layout, are you changing anything in the wizard?
edrosenthal350859
rounded image vs. square corner
here is the link.
www.chessclubforkids.com/
notice that in the upper corners a bit of white appears. that's what i am talking about.
thanks in advance for your reply.
Dani Chankhour
i have looked at your page and found the problem to be with this image:
3ColumnFixedRoundedCornerHeaderandFooter_images/header_top.png
The image includes the white background you are seeing. You will need to re-slice the image to not include the white portion (remove the white layer from the layout when you slice the image).
