Order multiple columns in recordset
Thread begun 11/19/2012 6:57 am by bill3786 | Last modified 11/21/2012 1:28 pm by Ray Borduin | 5399 views | 18 replies |
bill3786
The clients site has been running sucessfully for 4 months now but they have now asked for the following two changes.
1. Results from the database are displayed on the products_Results page using the default setting of ProductID ascending.
The client would now like to display the products ordered by the product price descending, showing the highest priced products first.
On this site there are two columns for prices, one column for UK customers in sterling (ProductPrice) and another for prices in euros for all non-UK customers (ProductEuroPrice).
The display of prices is controlled by an "if else" statement which depends on the the users country of origin selected at registration. So all UK registered customers (if) see sterling prices and are shown an "add to cart" button and can buy online in sterling. All non-UK customers (else) see euro prices only but dont see an "add to cart" button and are instructed to email their order and subsequently pay over the phone.
To order the display of products for the sterling prices ONLY would be a simple process by adding "ORDER BY ProductPrice DESC" to the recordset.
So my question is, how do you apply the "ORDER BY (for both price columns) DESC" statement in the recordset that will order both the ProductPrice (sterling) and the ProductEuroPrice columns for both UK and non-UK customers.
Attached are the product_Results and product_Detail pages.
Will the solution that is applied to the Results page affect the Detail page?
2. The display of products on the site is contolled in the recordset by a ProductLive column so that products with a value of 1 are displayed and those with a value of 0 are hidden.
The client would now like the facility to choose to display some of the hidden products but not allow them to be purchased, maybe with an "Out of Stock" message displayed somwhere or displayed on clicking the "Add to Cart" button or disabling the "Add to Cart" button etc etc. The client is open to suggestions on how this can be achieved on the site.
There is no stock control facilty on the site nor does the client want to add stock control, they simply want to be able to show some of the hidden products but not allow them to be purchased.
1) use a comma separated list of the columns to include in the ORDER BY Clause:
"ORDER BY ProductPrice, ProductEuroPrice DESC"
2) Use an if statement around the add to cart button to show an Out of stock error message:
<?php if($row_recordsetName['ProductLive'] != 0) { ?>
[add to cart button code]
<?php } else { ?>
This product is out of stock
<?php ?>
bill3786
Ok, thanks.
So that I'm crystal clear on how point 2 will work please could you describe in words how the if else will work. Site is live so need to be sure I understand what will happen before adding the new code.
$row_recordsetName['ProductLive'] is the binding for the ProductLive column of your recordset.
the if statement is checking that the value of the ProductLive column is not equal (!=) to 0.
if it is not equal to 0, it will show the add to cart button or else, it will show the error message.
bill3786
Ok, having a bit of a senior moment with this.
This is how I'm interpretting this.
The hidden product wont be visible on the website unless or until the client gives it a ProductLive value of 1 and then the if statement will cause the "add to cart" to show for a product they only want to display but not allow a customer to purchase.
the if statement would show the error message if the ProductLive column is 0 or the checkout button if it is not.
bill3786
The client doesnt want to show all the product in the database which have a value of 0 for the ProductLive column, they want to be able to choose which ones to show but cant be purchased. There are a lot of products in the database still without suitable images, some long term out of stock products and others which they want to display allbeit with the "out of stock" message.
Am I correct in assuming the system you describe will show ALL the products in the database as "out of stock" which have a value of 0?
yes, that is correct.
sounds like you need to create another column in the table to mark the items as outOfStock or not, and modify the if statement so that items where the outOfStock column equals 1 show the message and 0 shows the add to cart button
bill3786
Yes I think so, what about this.
Create a new database column called something like NoStock which had a default value of 1
Then the recordset which currently has only a WHERE ProductLive=1 statement would also need to allow products to be displayed which had a ProductLive value of 0 but a NoStock value of 0
Then the client would change the NoStock value from 1 to 0 for only the products it wanted to be displayed with an "out of stock" message in place of the "Add to Cart" button by using the if statement you gave earlier for the button but incorporating the NoStock column instead of the ProductLive column.
So it would be
<?php if($row_recordsetName['NoStock'] != 0) { ?>
<?php } else { ?>
<?php } ?>
Is this a working solution? If so how do I write the statements for the recordset starting with WHERE ProductLive =1
yes, that sounds right:
what do you mean? I dont think you would need to change the recordset at all.
