Cannot Update or Modify Search Parameters
Hi:
Whenever I try to modify Search Parameters in a Search sequence, it seems that WADA Makes DW5 Crash; for example, when I try to change a parameter from "Text" to "Date" or when I try to add a new parameter. When I click "OK" the message I get is the following:
"A problem caused the program to stop working correctly...." And then my only option is to shut the program down.
Any suggestions?
Thank you for your attention.
