Adding divs to ckeditor
Thread begun 11/16/2012 1:43 pm by bill3786 | Last modified 11/19/2012 8:34 am by Jason Byrnes | 6858 views | 3 replies |
bill3786
In ckeditor is it possible to wrap lines of text in the following div
<div class="content">Line of text 1</div>
This is part of a fading jquery script that displays each line of text in turn. In order to do this each line of text has to be wrapped in the div.
The cms content area is like this
<div class="content">Line of text 2</div>
<div class="content">Line of text 3</div> etc
Need this to be a simple operation for the client so that any of the lines of text can be removed and/or new ones added whenever they want. They wont be able to work in source view so is there a way to do this.
use the Div button in the toolbar to add a new div. see the attached screen shot.
bill3786
Ok thanks, that helps but it's not quite what I wanted.
I hope this explanation is easy to follow, I've shown a series of screenshots in the atachments. Bearing in mind the client cannot work in source view.
1.jpg is what we have to start.
We want to add a new fact after the first one and end up with 5.jpg and 6.jpg (see below).
So the client adds a line break after the first line and it looks like 2.jpg
But this adds the line break after the start of the second line div as shown in source view 3.jpg
Then when the client uses the "add div" button and adds the class name "content" it adds the new div inside the original second line div as shown in 4.jpg
For the fading jquery script to run through the lines of text in order the source has to be as 6.jpg (couldnt upload 6.jpg because of upload limit so here it is pasted below
A zebra is white with black stripes, not black with white stripes.</div>
This is the new fact that is to be added.</div>
It's impossible to fold any normal piece of paper more than 7 times (try it!)</div>
On average a four year old asks 437 questions a day.</div>
It is impossible for most people to lick their own elbow.</div>
If the client was familiar with html or I thought they could be trained successfully to consistently type in the code in source view then this wouldnt be a problem but this is not the case.
I hope you can follow this!
Unfortunately, this is a limitation in How CKEditor works when adding divs. it will treat the new div as a part of the existing div.
the only work around i have been able to find is to add a new block element to the page like a bulleted list, that would get added outside of the existing div, then with the bulleted list selected, add the div, this would add the new div around the bulleted list.
now in the tag selector, select the UL tag, and click the bulleted list button again to remove it, I have found this successfully creates the new div outside of the existing divs, the only draw back is that content inside the div is enclosed with a p tag that would need to be removed in source code.
