Insert Current Date
Thread begun 11/15/2012 8:50 am by jgroh96793 | Last modified 11/15/2012 8:57 am by Jason Byrnes | 1076 views | 1 replies |
jgroh96793
Insert Current Date
Hi all,
I did a search but didnt find a solution...how can I insert the current date when I am using the Insert server behavior? When I used the Interakt MX Kollection server behaviors, I would put in {NOW} in the dialog box. Can you do that inside the data assist Insert behavior?
John
theres a few ways to do this:
1) Set the default value for the date column to:
CURRENT_TIMESTAMP
Then no binding is needed in the insert, the database will automatically set the date column to the current date on insert.
2) create a hidden element and set the value to:
<?php echo(date("Y-m-d h:i:s")); ?>
the bind the date column to the hidden element
3) Instead of binding to the hidden element, set the code for the date column to:
