Power CMS p tags
Thread began 11/14/2012 11:20 am by bill3786 | Last modified 11/14/2012 2:00 pm by bill3786 | 1456 views | 6 replies |
bill3786
Power CMS p tags
Ive changed
$CKEditor_config = array();
to
$CKEditor_config["EnterMode"] = "CKEDITOR.ENTER_BR";
on the admin_cms/contents_insert.php and admin_cms/contents_update.php files but the p tags are still applied as shown in the source view and the actual text shows the typical p tag spacing.
clear the browsers cache and double check that the updates are uploaded properly.
bill3786
Cleared the cache and checked the two updated files. Have included the index page and two updated files.
The p tags are showing in code view, they are in the "Latest school news" section on the index page and are in a cms content area.
If I display source view in power cms and delete all the content so its blank and then add some text followed by enter it still inserts p tags and double spaces additional lines of text.
index.zip
user_insert.zip
user_update.zip
bill3786
Ok, just tried adding the st_replace function as below
<?php echo str_replace(array("<p>","</p>"),"",WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Home page', 'Latest school news content')); ?>
and it still adds p tags.
try using a lower case e:
$CKEditor_config["enterMode"] = "CKEDITOR.ENTER_BR";
bill3786
Brilliant, that was the problem.
