Start up errors
Dear Support, I'm getting the attached errors since I uninstalled my old WebAssist extensions and installed Design Extender and Data Bridge. Can you sort for me?
Go to WebAssist -> Preferences in the Memento section Set the Show in dreamweaver option to Never.
In the RSS Section, check the option to disable all RSS Feeds and Check For Updates only when Memento opens.
Then go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
Okay - problem solved - thanks
