Update Code not Working
Thread begun 11/10/2012 11:23 am by Mike Perry | Last modified 11/12/2012 9:44 am by Mike Perry | 3812 views | 10 replies |
Mike Perry
Using DB - latest version.
I have one field in a different table I want to update during a Record Insert.
This is the code that should create the Update:
mysql_query("UPDATE teacher SET booklist = 1 WHERE teacherID = ".$_SESSION['id']);
The update does not occur. If I replace $_SESSION['id'] with the data the update works.
Echoing both the $row_teacher['teacherID'] and $SESSION['id'] on the page show that they match.
The entire page is attached.
Thanks,
Mike
try using this code instead:
$updateSQL = "UPDATE teacher SET booklist = 1 WHERE teacherID = ".$_SESSION['id']."");
    $update_CMD = mysql_query($updateSQL, $WA_connection) or die(mysql_error());
Mike Perry
Returns the following error:
  Unknown column 'ADMIN' in 'where clause'
ADMIN is the $_SESSION['id'], and also the value in $row_teacherID. . .
ok, then the value needs to be enclosed in quotes;
$updateSQL = "UPDATE teacher SET booklist = 1 WHERE teacherID = '".$_SESSION['id']."'");
Mike Perry
Syntax error -- so many quotes, so little time. . .
what is the exact error, it should indicate a line number? and include a copy of the page.
Mike Perry
The syntax error is flagged in DW along with a Dynamically-related files error -- attempt to run in browser gives a blank screen
Page attached. .
hmmm, i dont see a syntax error in the code.
may try using this for the $updateSQL:
$updateSQL = "UPDATE teacher SET booklist = 1 WHERE teacherID = ".GetSQLValueString($_SESSION['id'], "text")."");
Mike Perry
Okay -- fixed one problem, created another.
The following code updates the teacher table:
  $updateSQL = "UPDATE teacher SET booklist = 1 WHERE teacherID = ".GetSQLValueString($_SESSION['id'], "text");
However the [Insert_ID] used for the redirect reports a zero ('0"), and the redirect to the Details page reports that the record has been deleted.
Mike
change the code order:
  $_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
