data assist: insert page error message
Thread begun 11/06/2012 9:23 am by eladgraphics386618 | Last modified 11/21/2012 2:45 pm by Ray Borduin | 3795 views | 12 replies |
eladgraphics386618
Hello
I have the insert page working before and I don't know what I did and I started having this error.
I have uninstalled the extension and re install it but I am having the same error.
While executing onLoad in WA_DFP_fileUpload.htm, the following javascript error occurred
in file "WA_DFP_fileUpload" initializeUI is not defined.
I don't know what I am doing wrong but I keep on having one error after another. I Prefer pay for the ticket and have someone show me what I am doing wrong. I will save time and money than looking in the dark for so many days.
thanks.
eladgraphics386618
I could not finish the ticket form. I am attaching the pages I have built so far.
thanks
Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
eladgraphics386618
Hello Jason
Thanks so much for the great work you guys are doing @ webassist.
I will try it and let you know. thanks so much.
elad
eladgraphics386618
data assist: insert page no images
Hello Jason
Thanks for the support - it worked.
1. The insert page
I have tried again and having these problems and need help. When inserting image I have the error message I do not understand. (attached message )
2. The detail page
My detail page came up with a black bock with the delete button inside even though I did not select the delete option. (attached page)
3. The result page
I know this is the css problem but I can not find it. Some of the blogs test are in the specified size and fit on the page and some overlap the page. ( You are not here to fix my css problem and I know you are have a lot to fix in one day. ) (attached page)
eladgraphics386618
Hello Jason
Thanks so much for the support.
I will be available from 9am to 3pm your time
dreamweaver cs6 and windows 7
thanks again
elad
eladgraphics386618
data assist: detail page - error on the page
Hello
Jason had followed up the ticket created and tell me where was the problem with the insert page but I am still having this problem I have mentioned with the detail page and I have forgotten to ask him when he was working on the insert page. (That was my #2 question)
2. The detail page
My detail page came up with a black box with the delete button inside even though I did not select the delete option. (attached page)
Even if I select the delete option the outcome page is wrong with the big black box at the bottom of the page.
Thank you for your time.
elad
eladgraphics386618
Hello
Sorry I forgot to attach page
eladgraphics386618
Hello
I know I am doing something wrong but I don't know what is it, that is why I need your help to fix this. I have tried another one the I got the same result with a big black box at the bottom and a lot of warning code (div, p etc..)
elad
