delete cookie behavior not working
Thread begun 8/07/2009 11:09 am by sandy170299 | Last modified 8/07/2009 11:35 am by sandy170299 | 4181 views | 4 replies |
sandy170299
I am using the cookies toolkit to create and then delete cookies in ColdFusion. It is not working. On my log out page, this is the script that I am using to delete the username cookie:
function WA_deleteCookie(cookieobj, cookiename, cookiecheck) {
if (cookiecheck) {
cookieobj.setValue(cookiename, "");
cookieobj.expire(cookiename);
</script>
This is the body tag: <body onload="WA_deleteCookie(WA_CookieObj,'username',true)">
But when I output the cookie value, it is still there: <cfoutput>#Cookie.username#</cfoutput>
Am I doing something wrong?
It would show on the page at first, since the server code runs before the onload code, but it should be gone when you refresh the page or go to another page without setting the username. It is also possible that you are setting it again somewhere.
sandy170299
The cookies toolkit script is not deleting the cookies. However, if I write manual code to do so it's working. At least I have a workaround....
Is the javascript being called properly? You may want to try adding in an alert() to see if the script is running at all. Maybe the necessary functions or includes aren't on the page. There are several possibilities why it may not have worked, but I guess you probably have a workaround so it dosn't matter much.
sandy170299
It would be nice to have it all automated, because I'm tired of writing my own login scripts :), but as long as I have a workaround, I'm fine with that.
