Operation must use an updateable query.
Thread began 11/05/2012 2:19 pm by john70964 | Last modified 11/06/2012 7:16 am by john70964 | 1496 views | 4 replies |
john70964
I know this is old hat and everyone may have forgotten .asp.
I have a page its called edit_profile.asp its in a Login Procedure.
It works OK on my local PC but does not work on my 1and1 server.
On there I get
Microsoft JET Database Engine error '80004005'
/Login/Login/Login/edit_profile.asp, line 131
The Update Record(Users form"EditProfile") has a Red Exclamation Mark in front.
All of the other database connected pages work OK.
I attach the file perhaps someone can see what can be wrong with the page.
Many thanks
John
Since the error is a Jet error, i'm assuming you are using an Access Database. The problem is most likely that the database does not offer write access, it is most likely set to read only.
see this page for details:
306269
this page:
80004005-errors.html
and this page:
how-do-i-solve-operation-must-use-an-updateable-query-errors.html
john70964
Yes of course you are so correct!
Should I have
"Read and write" and not "Read and Execute", I seem to recall having all three ticked caused security problems.
Thank you
John
I dont think you need execute ticked, read and write should be good.
john70964
Thanks Jason will give it a go.
