Invalid Field Count CSV Input on Line 1
I've been having issues with getting close to 10,000 subscribers into pm1_users.
1. I tried to import an xls file but have learned that no longer works.
2. To be sure there isn't something wrong with the database, I started with just one subscriber and created a CSV file. I've tried it with the exact field names as pm1_users and the header and the same without the header. In both cases I get Invalid Field Count CSV Input on Line 1
3. I'm told that "the column count in the CSV file does not match the column count of the table you are importing to." But I'm clueless as to how I correct that. In Numbers, I've assigned the length of each column to be the same as pm1_users. What am I doing wrong?
