Auto increment a # in a repeat region
Thread begun 11/05/2012 5:28 am by SPT | Last modified 11/05/2012 10:12 am by SPT | 3976 views | 2 replies |
SPT
I am trying to make a slider that is connected to a recordset. However for each repeated region it needs to increment up one number.
Original code that needs to increment.
First slide needs to be:
<div id="p7HGMpn_1_1" class="p7HGM_panel">
<div id="p7HGMpc_1_1" class="p7HGM_panel_content">
The next slide repeated from the RS (and so on incrementing one number) needs to be:
<div id="p7HGMpn_1_2" class="p7HGM_panel">
<div id="p7HGMpc_1_2" class="p7HGM_panel_content">
I tried making a variable and placing it in the slide but no joy.
Here is how I tried:
My variable :
<?php $i = 1;?>
Then placed it:
<div id="p7HGMpn_1_<?php echo $I = $i + 1;?>" class="p7HGM_panel">
<div id="p7HGMpc_1_<?php echo $I = $i + 1;?>" class="p7HGM_panel_content">
Parsed code for every panel comes out:
I understand why it does not work but I can not figure out how to make it work.
initialize the variable just before the do statement:
<?php i = 1; ?>
do{ ?>
reference the $i variable in the ID's:
<div id="p7HGMpn_1_<?php echo $i; ?>" class="p7HGM_panel">
<div id="p7HGMpc_1_<?php echo $i; ?>" class="p7HGM_panel_content">
increment the variable just before the while statement using ++
<?php $i++ ?>
} while ($row_Recordset1 = mysql_fetch_assoc($Recordset1)); ?>
SPT
OMG Jason you are my hero!!!!
THANK YOU!
Another really cool thing: I made the page with just the slider and nothing else then used Framework to drop it into a page and it worked mint! 2 clicks and Done.
Where would I be without my WA. :)
