Manage Relational Table, retrieving data for update form fields
Thread begun 11/01/2012 6:02 am by CraigR | Last modified 2/14/2013 2:30 am by Nico | 2119 views | 3 replies |
CraigRBeta Tester
Don't know if this is possible via this method, but here goes.
I have a product with several related tables, for each of which i have added manage related tables server behavior.
Slightly more complex than the blue sky example, some related options have an associated price - which is dependent upon its productid, so the price field is in the many to many table.
my insert page is working fine, however, i cannot recover the price in the update page.
looking at the code, it looks like the mrt server behavior creates a block of code called WA DataAssist Pre-Select Relational Table (x) which is used to retrieve the optionid from the table, but i also want to recover the price.
i tried editing the code from
// WA DataAssist Pre-Select Relational Table 2
$WA_PreSelect_RelationalTable_2 = array();
$WA_connection = $simon;
$WA_table = "tblproductcolour";
$WA_masterKeyField = "ProductID";
$WA_masterKeyType = "none,none,NULL";
$WA_masterKeyValue = "".$_GET['ProductID']  ."";
$WA_masterKeyComp = "=";
$WA_joinedKeyField = "ColourID";
$WA_connectionDB = $database_simon;
mysql_select_db($WA_connectionDB, $WA_connection);
$WhereObj = WA_AB_generateWhereClause(array($WA_masterKeyField), array($WA_masterKeyType), array($WA_masterKeyValue), array($WA_masterKeyComp));
$WA_Sql = "SELECT ".$WA_masterKeyField.", ".$WA_joinedKeyField." FROM ".$WA_table." WHERE ".$WhereObj->sqlWhereClause." ORDER BY ".$WA_joinedKeyField;
$WA_mrtJoinRS = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
if (
mysql_num_rows($WA_mrtJoinRS) > 0) {
  while (
$row_WA_mrtJoinRS = mysql_fetch_assoc($WA_mrtJoinRS)) {
$WA_PreSelect_RelationalTable_2[] = $row_WA_mrtJoinRS[$WA_joinedKeyField];
to
$WA_extraField = "Price";
$WA_Sql = "SELECT ".$WA_masterKeyField.", ".$WA_joinedKeyField.", ".$WA_extraField." FROM ".$WA_table." WHERE ".$WhereObj->sqlWhereClause." ORDER BY ".$WA_joinedKeyField;
if (
  while (
adding the extra field price, so i can get the field into the 'recordset' , but can't work out how to set the value of my price text field.
CraigRBeta Tester
Problem resolved with (help of) a support session
The easiest way to achieve this is to leave the pre select query alone and change the recordset which populates the check boxes,
so that instead of returning just the rows from the reference table, you first filter the rows which have a price (by productid), then create a nested query with a left join, so you return all the rows with the colourid AND all of the related prices, for a particular product.
then you set the value of your price field from the recordset
eg
SELECT refcolour.ColourID, refcolour.ColourDescription, rspriced.Price FROM refColour LEFT JOIN ((SELECT ColourID, Price FROM tblproductcolour WHERE ProductID = %s) as rspriced) ON refcolour.ColourID = rspriced.ColourID
sorted !
Nico
Thank you
It works great.
Thank you.
