Page reloads
Thread begun 10/31/2012 4:15 pm by Armen | Last modified 11/02/2012 9:36 am by Armen | 4265 views | 7 replies |
Armen
Page reloads
DW CS5.5 PHP UE 4.0.1
The page with the UE extension simply reloads when I click submit. Here is the ,form> tag: <form action="" method="post" id="form1" onsubmit="MM_validateForm('Name','','R','Email','','RisEmail');return document.MM_returnValue">
is it missing the action?
The form action should be left blank.
in the universal email behavior, you can set the Go To Page option to have it redirect to another page after sending the email.
Armen
The Go To Page option is set. It seems the page is not doing anything but reloading. The email does not go through. You can see the page here: contact-halohookah.php
send a copy of the page in a zip archive please.
Armen
How do I do that?
Armen
I know how to zip. How do I send you the file?
Armen
Here is the file
This post has been deleted.
In universal Email, instead of using the Current Page Submit trigger, try using the Button Submit pressed trigger.
Armen
That did the trick. Thanks!
