Fatal memory error
Thread begun 10/31/2012 9:59 am by kbettenc296716 | Last modified 10/31/2012 11:13 am by kbettenc296716 | 3812 views | 6 replies |
kbettenc296716
Fatal memory error
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 24576 bytes) in C:\inetpub\wwwroot\LDG2012\Templates\admin.dwt.php on line 24
I got this error when I was bringing up artists_search.php in a browser on my testing server.
add the following code at line 1 of the artists_search.php file:
ini_set
("memory_limit", "256M")
kbettenc296716
Different error
PHP has encountered a Stack overflow
I don't get the previous message but get this.
can you send a copy of the Templates\admin.dwt.php and the artists_search.php files so i can examine the code.
kbettenc296716
Here are the files
It is happening with all the php files created by Datassist this time around.
it looks like you have code to apply a theme on the template file.
the code above the doctype tag on the admin.dwt.php page:
<?php require_once('../webassist/framework/framework.php'); ?>
require_once('../webassist/framework/library.php'); ?>
require_once('../Connections/connLDG.php'); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  if (
PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return
$theValue;
mysql_select_db($database_connLDG, $connLDG);
$query_rsArtists = "SELECT * FROM artists ORDER BY artLastname ASC";
$rsArtists = mysql_query($query_rsArtists, $connLDG) or die(mysql_error());
$row_rsArtists = mysql_fetch_assoc($rsArtists);
$totalRows_rsArtists = mysql_num_rows($rsArtists);
if(
$WA_admin_1_Content_Empty = "";
$WA_admin_1_Content = new WA_Include(__FILE__);
$WA_admin_1_Template = new WA_Include("../Templates{$WA_admin_1_Content_Empty}/admin.dwt.php");
    require(
$WA_admin_1_Template->BaseName);
$WA_admin_1_Template->Initialize(true);
and below the </html> tag:
if(isset($WA_admin_1_Template)){
$WA_admin_1_Content->Initialize();
$WA_admin_1_Template->ReplaceTemplateRegions($WA_admin_1_Content);
    print(
$WA_admin_1_Template->Content);
mysql_free_result($rsArtists);
should not be on the template file.
kbettenc296716
That did it.
