Multiple image upload
Thread begun 10/31/2012 7:38 am by john70964 | Last modified 11/01/2012 10:14 am by Jason Byrnes | 4409 views | 7 replies |
john70964
I have two file fields in a submit form to a table
Each file field should submit a main image and a thumb
Both main images are inserted but only one thumb.
The thumb images for Image2 is not inserted.
I copied the Bindings from the Insert Single Record SB I am using.
Image2 looks rather short but is inserting the correct information.
Bindings below.
Image1 <?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"]; ?>
Image1_thumb <?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_2"]["serverFileName"]; ?>
Image2 <?php echo $WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"]; ?>
Image2_thumb <?php echo $WA_DFP_UploadStatus["WA_UploadResult2"]["WA_UploadResult2_2"]["serverFileName"]; ?>
I also attach a copy of the file in the hope you can see where I am going wrong.
Many thanks
John
to help troubleshoot the problem, well need to make a few changes to the page to get some aditional information.
1) add the following code at line 1 to turn on error reporting:
error_reporting
(E_ALL);
ini_set('display_errrors','on');
2) remove the redirect URL. Change:
$WA_redirectURL = "thankyou.php";
$WA_redirectURL = "";
3) Echo the insert SQL.
change the following code:
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
echo("SQL: ".$WA_Sql."<br />");
4) output the files array to the page.
add the following code just before the </body> tag:
<?php var_dump($_FILES); ?>
5) Add the debug info bindings. Go to the bindings panel and expand the WA Uploaded Files binding Global Status binding group and drag the debug info binding to the page.
this will add a bunch of information to the page after testing it again, post this information back please.
john70964
Thank you Jason
Please find information displayed on test page
john70964
This post has been deleted.
this looks like the information before testing the insert.
I need the information on the page after trying the insert. It should also include the insert SQL.
john70964
I hope I now have it below?
array(2) { ["Image1"]=> array(5) { ["name"]=> string(11) "cai2070.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(22) "C:\xampp\tmp\php64.tmp" ["error"]=> int(0) ["size"]=> int(33951) } ["Image2"]=> array(5) { ["name"]=> string(11) "cai2071.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(22) "C:\xampp\tmp\php65.tmp" ["error"]=> int(0) ["size"]=> int(30472) } } Status object: WA_UploadResult1
statusCode : 1
errorMessage :
clientFileName : cai2070.jpg
fileExtension : jpg
serverFileName : cai2070_12.jpg
serverSimpleFileName : cai2070_12
serverDirectory : boatimages\
contentType : image/jpeg
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed : 1
fileSize : 24982
isImage : 1
imageWidth : 345
imageHeight : 650
WA_UploadResult1_1:
fileExtension : jpg
fileSize : 24982
imageWidth : 345
imageHeight : 650
isImage : 1
fileWasSkipped :
fileWasRenamed : 1
statusCode : 1
WA_UploadResult1_2:
fileExtension : jpg
serverFileName : cai2070_thumb_12.jpg
serverSimpleFileName : cai2070_thumb_12
fileSize : 5368
imageWidth : 120
imageHeight : 226
isImage : 1
fileWasSkipped :
fileWasRenamed : 1
statusCode : 1
Status object: WA_UploadResult2
statusCode : 1
errorMessage :
clientFileName : cai2071.jpg
fileExtension : jpg
serverFileName : cai2071_7.jpg
serverSimpleFileName : cai2071_7
fileWasSkipped :
fileWasRenamed : 1
fileSize : 18389
isImage : 1
imageWidth : 345
imageHeight : 650
WA_UploadResult2_1:
fileExtension : jpg
fileSize : 18389
imageWidth : 345
imageHeight : 650
isImage : 1
fileWasSkipped :
fileWasRenamed : 1
statusCode : 1
WA_UploadResult2_2:
fileExtension : jpg
serverFileName : cai2071_thumb_7.jpg
serverSimpleFileName : cai2071_thumb_7
fileSize : 4597
imageWidth : 120
imageHeight : 226
isImage : 1
fileWasSkipped :
fileWasRenamed : 1
statusCode : 1
you don't include the SQL?
john70964
My apologies Jason
I copied my original file to send to you to show why it was not working.
Just now I decided to send you a fresh copy ammended as required.
I decided to give my original copy another test and its working OK.
I have no idea why this has happened. Most strange.
Ok, if it happens again, let us know and we con look into it.
