Php Above Html
Thread begun 10/30/2012 9:15 pm by theorytl401135 | Last modified 10/31/2012 12:15 pm by Jason Byrnes | 6378 views | 11 replies |
theorytl401135
Php Above Html
How can I get php to execute above the HTML in a plugin with Framework Builder.
When I do something as simple as <?php echo('Hello World');?> before the HTML in a plugin and run the page it is included in, nothing happens.
Please advise, thanks.
mikehesson45442908
Hello,
What you want to exactly. i can't understand but below link might be helpful to you.
framework-builder_gsg.php
Thanks and Regards,
Mike
make sure that the page you are using as a plugin is a full html page with <html> <head> and <body> tags in it, for example:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Untitled Document</title>
</head>
<body>sample Body text
</body>
</html>
the Plugin engine looks for the doctype tag and adds code before the doctype tag to the page it is plugged into before the doctype tag on that page.
it breaks the head and body sections of the page up and adds the code to the respective sections of the main page.
if those tags are missing, then the plugin engine has no way to know what sections the code belongs to.
theorytl401135
Thanks for this info Jason.
theorytl401135
Hey Jason, I am still not able to see the echo. Are there any other conditions that I should consider?
send a copy of your pages please.
theorytl401135
Here you go.
the code for the echo is wrong. you need quotes around the string to echo
<?php echo(test); ?>
will cause an error.
it needs quotes:
<?php echo("test"); ?>
theorytl401135
Sorry about that, I was trying it on another page to see if it made a difference and type it wrong. That does not affect anything I'm still not seeing it.
normally code from above the doctype is not added to the main page.
normal the code above the HTML is used to generate the page body, then the page body is displayed.
why is it you want the code from above the HTML on the header page included?
