Hidden value on delete getting wrong id
Thread begun 10/30/2012 7:20 am by Nico | Last modified 11/01/2012 12:38 pm by Jason Byrnes | 2377 views | 4 replies |
Nico
Was testing an administration page and realised that on the 'results' page delete button was functioning but no delete was being made.
Changed the 'WADADeleteRecordID' from hidden to text to see whats going on and realised that for some reason it was assigned with a wrong id. For example my record id had a value of 16 but this field was getting a value of 12. I re-binded the id value to this field but same thing was happening.
So the real problem is that button is functioning but because of the wrong id that the hidden field is getting, script is deleting wrong record or not deleting anything.
Thank you
PS Attaching file
The hidden form element shouldn't need a binding value at all. It should be set with javascript when you click the delete button for the associated row.
Do you have a url where I can view the problem? I can take a look and see if I can spot the problem. Maybe there is a javascript error on the page that would give me a clue to the source of the problem.
Nico
Right now I am testing it locally. I ll try to fix the problem and if not when file uploaded I will send you the link. Thank you
Nico
Well I think I found what was wrong.
Had declare the id field in my database as 'unsigned zerofill'. Putting it back to default made delete action work ok.
Don't know why but 'unsigned zerofill' causes delete problems
the ID should be an integer, the auto increment database function wont work with the unsigned zero fill data type.
