Insert into column if other column =
Thread begun 10/30/2012 5:06 am by georgina_barrett_187762 | Last modified 10/31/2012 5:07 am by georgina_barrett_187762 | 1272 views | 2 replies |
I have a normal insert page, but I want to insert data into one of the columns depending on the value of another 2.
For example, if field1 = 1000 OR 2000 AND if field2 = 2 OR 3 then insert 'red' into field3.
You could use some php code in the binding for field 3:
<?php echo((($_POST['field1_form_field'] == "1000" || $_POST['field1_form_field'] == "2000") || ($_POST['field2_form_field'] == "2" || $_POST['field2_form_field'] == "3"))?"red":"green"); ?>
I'm assuming you are inserting the values for field1 and field2 on this page as well, but basically you need to write an if statement like this one to achieve that result.
Thank you, That worked.
