Successful login
Thread begun 10/29/2012 2:41 pm by Jack Stockton | Last modified 10/29/2012 4:46 pm by Jason Byrnes | 2038 views | 1 replies |
Jack Stockton
Successful login
I would like to keep track of when a user logged in last.
How can I log to the pcms2_users table the last successful login date time?
you would need to leave the success redirect in the authenticate user behavior blank, then add an Update record behavior to update the users table and add the current date.
The login saves the users ID in a session variable, use that session as the Primary Key value in the update behavior, and use the following code for the loginDate column binding:
<?php echo(date("Y-m-d h:i:s")); ?>
