Some advice needed for Data Bridge
Thread begun 10/26/2012 7:23 am by mrs | Last modified 10/26/2012 7:32 pm by Jason Byrnes | 2199 views | 3 replies |
mrs
I saw a tutorial from WA with regards to joining the contents of a database, but I can't for the life of me find it now, and apart from being different subject matter, it looked to achieve exactly what I need.
I have a page with a master recordset and a child recordset. This master recordset will hold the unique IDs to return content for related child recordset. This related content is in another DB table, and it is a table with five or six promotional records in it; the administrator can choose to apply a promotion to multiple records from the master table.
So, I am trying to achieve this:
Pull in content to a page from a master record which in turn triggers the content for the child record which is the promotional content. This master record has loads of columns, one of which holds the unique ID of the related promotion.
Now, if I structure my SQL like this, it only returns the first promo record from the results regardless of the promo ID entered into the master record column:
Type: INT
Default value: -1
Runtime value: $_GET['tbl_master.fld_promoRELATED']
SELECT * FROM tbl_promo JOIN tbl_master ON tbl_master.fld_promoRELATED = tbl_promo.fld_promoID WHERE tbl_master.fld_promoRELATED = promovar
If I use a default value of 3 for example, then the promo record with ID 3 is returned. Basically, the results aren't displaying dynamically. The info in the master record is effectively being ignored. Somewhere a variable is missing that should match that of the master record in order to return the promo record, and it's here that I am stuck :(
Does this make sense? If so, how can I achieve this with Data Bridge?
Thanks.
Mat
i think the tutorial you are thinking of is the "Displaying Relational Tables with Plug-ins" tutorial on the data bridge page:
data-bridge/
how are the links created?
tbl_master.fld_promoRELATED doesn't look like a valid url variable name to me.
mrs
Ah right, I am trying to get it to look straight at the contents of the column within the master recordset / DB table rather than some session or URL variable.
I was assuming that if I ordered the code so that the master recordset came first, followed by any child recordsets, I could take the values in the promo column and join it to the unique ID of the promotional content table.
Is it not possible to get it to look straight at the contents of a table? Is that what I am doing wrong? I've tried to build this manually, and I must admit, it has taken quite a while to get where I am just for it to not work properly, and I assumed that Data Assist and other tools from Data Bridge would enable me to achieve this quicker and successfully.
Originally Said By: mrs
Well, then dont use a where clause.
the ON section of your query:
tells it to compare the tbl_master.fld_promoRELATED column with the tbl_promo.fld_promoID column and return results where they are equal
by adding the where clause:
and using a GET variables, you are telling it to restrinct the returned results to only where the tbl_master.fld_promoRELATED column is equal to the URL being used.
