uploaded file names need to be lower case
Thread begun 10/25/2012 8:23 pm by htm2112 | Last modified 12/06/2012 6:15 am by yagyamc444384 | 3009 views | 2 replies |
htm2112
I have been having trouble with this off and on. How can you ensure that all files uploaded will be lowercase? If any part of the filename is uppercase, the image does not display.
I found that if you add the following after line 86 in helper.php, you get partway there:
$attemptedFileName = strtolower($attemptedFileName);
Problem is that if the file exists, I have set the option to rename the new file. But the renamed new file does not become lowercase.
So If I am uploading DCSN101.jpg, this fix turns it into dcsn101.jpg. But if I upload it again, it turns into DCSN101_1.jpg.
How can I ensure that
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "image", "2", "[FileName]_[Increment]", "JPG:80", $WA_UploadResult1_Params);
makes what is stored in [FileName]_[Increment] lowercase?
try adding the following code at line 1 of your page:
if(isset($_FILES)) {
    foreach(
$_FILES as $k => $v) {
$_FILES[$k]["name"] = strtolower($_FILES[$k]["name"]);
yagyamc444384
Message to htm2112
Hello htm2112,
I'm Michael a.k.a Yagya from themeforest. . I wanted to ask if you would be kind and able to send me the wordpress version of The Clothes Shop theme please? I posted on the link below but I couldn't find your email address anywhere so am sending you a personal message here..
Kindest,
Yagya
46980?page=3
