Redirect user to back only their listings
Thread begun 10/25/2012 7:24 pm by jo271221 | Last modified 10/26/2012 7:23 am by Jason Byrnes | 1043 views | 1 replies |
jo271221
Upon deletion of a post I would like to redirect the member back to only their listings verses all listings. I tried this: $WA_redirectURL = "p-search-results.php?customerid=<?php echo($row_WADAtbl_post['description']); ?>"; and it should me that I had a syntax error.
yes, the synta error in this code is that you have the php tags.
instead of:
it should be:
$WA_redirectURL = "p-search-results.php?customerid=".$row_WADAtbl_post['description']."";
however, this is passing the description from the recordset, not the id.
also, for what you are trying to accomplish, you don't need to pass anything in the URL.
When a user logs in, their ID is stored in a session
on the results page, set the recordset to filter using the ID Session variable, for an example of this, see the profile page created by the security assist wizard.
