Floaters has no properties
Thread begun 10/25/2012 1:28 pm by Jedi | Last modified 10/25/2012 1:35 pm by Jason Byrnes | 1125 views | 1 replies |
Jedi
I just updated databridge to 109 and when trying to build cms I get the error \CS5.5\en_US\Configuration\Floaters\WA_SiteTools_ProgressV2.js:getAvailableColumnByName(wa.dataassist_settings.available_columns,keyCol) has no properties and it stops working at the creating update page.
I have uninstalled the extension and deleted the .dat file and reset the workspace several times and I still get the message.
this error usually happens if your table does not have a Primary Key column defined.
if you continue to have problems, see this post:
showpost.php?p=137687&postcount=2
