Count in a selection box
Thread begun 10/25/2012 11:47 am by john70964 | Last modified 10/29/2012 1:40 pm by john70964 | 6813 views | 16 replies |
john70964
Hello
I wish to create a selection box which when a selection is made will indicate how many of that item is available.
I have tried the attached code but it shows only the quantity of the first item and does not update when a further selection is made.
Can anyone please assist me with this please?
Many thanks
John
you need to submit the selection to get the count for the selected item
you need to submit the selection and create another recordset to return the count, set the recordset to filter by the selection made so that the count is for the selected product.
john70964
Quote
"you need to submit the selection to get the count for the selected item".
I can see the need to update the table when outside of the box is selected.
Can you please say how this is achieved?
I see the need to create a second recordset but cannot see how the second recordset is caused to filter by the selection made in the first recordset.
to submit the form, add a submit button and click it
to filter the recordset, set the filtering options in the recordset dialog box.
this is rather basic Dreamweaver usage.
john70964
Thanks Jason
Re "to submit the form, add a submit button and click it" Sorry I misunderstood.
When creating the second recordset as suggested below
"set the recordset to filter by the selection made so that the count is for the selected product."
I cannot see how to do this in the second recordset from the filters allowed in the wizard.
I attached a pic to show my meaning.
the name of your form variable is Category
so in the filtering, section select the Form variable Filter option and set the name in the box next to the select list to "Category"
you then need to go into advanced view, and add the COUNT() condition to the recordset select.
john70964
Thanks Jason
I have used the form variable in the recordset but cannot get a total to show.
I am attaching a pic of the recordset if that helps.
you need to use an alia on the count :
SELECT Category1, COUNT(Category1) as categoryCount
etc....
then from the bindings panel, use the categoryCount binding on your page.
john70964
I think I did as instructed but I cannot get a result in the CategoryCount.
I show my details in the attached image.
John
send a copy of the page please and a link where i can see the problem.
