Repeating Table problem
Thread begun 10/24/2012 7:54 am by davegw | Last modified 10/26/2012 5:55 am by davegw | 3629 views | 3 replies |
davegw
Data Bridge Repeating Table is not working.
I've been trying out your tutorial at:
data_bridge_repeat_table.php
and the number of table columns selected (e.g. 5) in the Repeating Table UI is ending up in the Repeat Region SB as:
$maxRows_rsItems = -5;
Previewing the page returns a php error.
Surely this should give you a repeating table with 5 columns?
Cheers
Dave
change:
$maxRows_rsItems = 5;
the minus sign is causing the problem.
what Data bridge version are you using? I believe this should be fixed in the 1.0.9 version, if you have a previous version installed, uninstall it from the extension manager and install the newer one.
davegw
Jason - I tried changing it to 5, but this changes the number of repeating rows. I set the columns to 5 and the rows to 'all records'. I still have Data Bridge 1.0.8, so I'll upgrade to 1.0.9 now then let you know if that fixes the problem. Yes I see one of the fixes is:
"Corrected an issue that caused a run-time error to occur when using Repeating Table with the ‘Show All Rows’ option enabled."
Cheers
Dave
davegw
Thanks Jason - after upgrading to Data Bridge v1.0.9, all fell into place. I was confused about the column number that is actually the number of 'Repetitions'. To get extra *field* columns I just added the columns to the repeating table then inserted the bindings.
Cheers
Dave
