wacsssculptor.dll error mesage
Thread begun 8/07/2009 7:03 am by shaun.m.rafferty304669 | Last modified 8/07/2009 1:04 pm by Dani Chankhour | 2029 views | 1 replies |
Receiving message "wacsssculptor.dll" when trying to remove and/or update extension.
Have already tried deleting WinFileCache.dat file...
Dani Chankhour
I recommend deleting your Configuration folder and re-install the extension. Make sure to get the latest dot release from your download center. Here is the instruction on how to delete your configuration folder:
Close Dreamweaver and go to:
WinXP
-DW8
--C:\\Documents and Settings\\<Your User Name>\\Application Data\\Macromedia\\Dreamweaver 8
-DWCS3
--C:\\Documents and Settings\\<Your User Name>\\Application Data\\Adobe\\Dreamweaver 9
-DWCS4
--C:\\Documents and Settings\\<Your User Name>\\Application Data\\Adobe\\Dreamweaver CS4\\en_US
Win Vista
-DW8
--C:\\Users\\<Your User Name>\\AppData\\Roaming\\Macromedia\\Dreamweaver 8
-DWCS3
--C:\Users\\<Your User Name>\\AppData\\Roaming\\Adobe\\Dreamweaver 9
-DWCS4
--C:\\Users\\<Your User Name>\\AppData\\Roaming\\Adobe\\Dreamweaver CS4\\en_US
Mac OSX;
-DW8
--Hard disk: Users: <Your User Name>: Library: Application Support: Macromedia: Dreamweaver 8
-DWCS3
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9
-DWCS4
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US
(Please note that <Your User Name> Should be replaced with the User name you use to log into your computer)
Rename the configuration folder to configuration_back. This will have the effect of disabling all of the installed extensions. You should open the extension manager and remove all extensions to clear the extension mangers cache. After removing the extensions you can then reinstall them making sure to download the latest versions from your order history.
NOTE:
On Windows Computers, The AppData or Application Data folders may be set to be hidden.
To View Hidden Folders in Windows Vista:
1) In The Windows Explorer, Click the "Organize" button
2) Select "Folders And Search Options"
3) Select the "View" tab
4) Click the "Show Hidden Folders And Files" radio button.
To View Hidden Folders in Windows XP:
1) On the Tools menu in Windows Explorer, click Folder Options.
2)Click the View tab.
3) Under Hidden files and folders, click Show hidden files and folders.
