PowerCMS & PowerStore Incompatibility?
Thread begun 10/24/2012 7:46 am by wdtp.com | Last modified 10/24/2012 1:38 pm by Jason Byrnes | 3823 views | 5 replies |
wdtp.com
I'm trying to setup PowerCMS on a site with PowerStore installed and am receiving the below error:
Parse error: syntax error, unexpected T_STRING in /nfs/c07/h01/mnt/99644/domains/boyersjewelry.com/html/WA_Globals/WA_Globals.php(56) : eval()'d code on line 1
See: index.php
when installing 2 solution packs in the same site, they need to be installed in seperate folder.
you would need to install Power CMS in one folder, and power store in a separate folder of your site.
bear in mind, that power store includes power CMS functionality already so using the power CMS content on a page that includes power store will not work.
wdtp.com
I have done that. Something else going on?
PowerStore is installed at:
store/
PowerCMS is installed at:
admin_cms/
Still don't understand why I receive the error:
in the WA_Globals.php file, change line 58:
eval("\$WAGLOBAL_".$value[$x][4]."='".replaceTokens($value[$x][1],$tabs)."';");
eval("\$WAGLOBAL_".$value[$x][4]."='".addslashes(replaceTokens($value[$x][1],$tabs))."';");
wdtp.com
That worked!
Should this change be implemented in future installations or is this just specific to my installation?
Thanks!
it normally happens in older versions when an apostrophe is used for the store name, the change shouldn't be needed if you avoid using an apostrophe.
